Hello how do I enable the function to always have the control strip on. It should not dim to save battery. No other functions should be active on the left side. Thanks
unfortunately that’s not possible (it would cause burn-in on the OLED display of the Touch Bar)
I was looking for this answer as well but for the reason to stop the touch bar's annoying flickering (like a strobe light). Does BTT have any settings to help with that?
