control center shows up randomly , even tho i deleted all of my triggers related to "show control center"
control center shows up kinda randomly when i use better touch tool. even tho i disabled all related triggers, i think that when i click on the top of the trackpad it'll show control center and block my typing
it definitely comes from better touch tool as i set up my mac anew and have had nothing else on it
is there a way to revoke sysUI access ? i got prompted to grant BTT rights for it , and i think it's what allows to control UI things like control center
macbook air m1 , ventura 13.01. and 13.1
  • Type of Mac: macbook air m1
  • macOS version: ventura 13.0.1 and 13.1
  • BetterTouchTool version: 3.962 (2127)
    **Additional information : i supose removing sysUI access would "fix" that issue
mh no, for control center BTT doesn't need any permissions.
In general BTT only triggers control center via the "Show Control Center" action, are you sure that action is nowhere to be found?
It could also be some key combination that is triggered or it could be set up for a specific application.
If you can't find it, go to Help => Export Diagnostic Debug Information and send the result to andreas@folivora.ai, then I can check
yeah . i restored through dropbox , which may not have been a good idea right ?
i deleted all triggers related to control center and rebooted the laptop
i had the same issue on my previous mac through the last 4 BTT updates i think
i'll go dig again and send the diagnostic if i don't find anything
as an asides, do you have any news on the new BTT remote ?
and thanks again for working so hard on BTT, you're amazing
i sent you the mail
as an aside , as i told you in mail ,I also have another issue with BTT quitting randomly btw..like sometimes I’ll try to perform a gesture, just to notice that btt isn’t running
maybe i should delete BTT completely and re-do my setup each gesture one by one
if there is no solution and i end up doing so , how can i ensure that BTT is fully deleted and all of its files as well ?
In the Mail app you have configured a "1 Finger Tap Top Right" that has "Show Control Center" assigned. Is that maybe what triggers your issue?
For the crash: could you check whether there are any BTT crashlogs in the macOS console app under "Crash Reports"?
oh thanks , i just deleted that.i will see if it helps. i don't recall ever making any mail setup .
as for the crash log i had rebooted my mac in the meantime so i'll have to wait for BTT to crash again, and when it does i'll report it to you !
thank you very much
