Hello
I am currently trying to add a Context Menu extension to the Find menu.
Unfortunately I can't find BTT in the settings under Login Items & Extensions...
What am I doing wrong?
thanks for an answer
Hello
unfortunately for some reason this is currently missing on macOS Sequoia. However BTT now has a button to activate the extension (restart Finder afterwards by opt+right-clicking the Dock icon and selecting "relaunch")
Thank you very much, it might also be good for future users if it were adjusted here in the documentation, if Apple doesn't fix it soon Extending Finder Context Menu ยท GitBook
