Hello all,
I'm new to BTT and I'm learning to customise my tool bar to suit my usage.
I have a question and was wondering if someone could help (already tried looking for answers here on the forum and had no luck).
Is there way to only show the "Hide browser tabs" and "Show browser tabs" icon when the menu bar is expanded to medium or large?
Your help is highly appreciated!
Thanks in advance,
Cyrus
Sorry, I'm a little confused, which browser are you talking about? I didn't see any options regarding to "hide/show browser tabs" in Safari nor Chrome.
I think some screenshots would be more helpful.
Hi Noon,
What I was referring to was the BTT configuration.
I have the Golden Chaos preset loaded. On the left hand pane, I could see "Menu Bar [Hide Browser Tabs" and "Menu Bar [Show Browser Tabs]".
I was wondering if there was a way, to only display these when the menu bar (right hand side of the touch bar) is at medium/large?
Well, you should add a GoldenChaos tag in your post, then the developer may answer you.
I don't have this preset, sorry I don't know how.
OK. Thanks for the reminder - tag added!
