Connect to wifi trigger not working
Tried using Alpha v4.621.
I'm trying to switch network locations and using wifi SSIDs as a source of truth to trigger this.
When adding a trigger for "Did Connect to Wifi with Name" the currently connected wifi variable is "(null)". This doesn't update when I change the SSID I'm connected to.
The task I'm trying to fire is "Execute Shell Script" and I'm running scselect "Location Name Redacted". Running this manually it works correctly.
As a new user I'm unable to upload a screenshot or logs.
  • Type of Mac: MacBook Pro 16" 2023 M3 Max
  • macOS version: Sonoma 14.5
  • BetterTouchTool version: 4.621
