Connect Bluetooth Midi Device
Hi
There is a very useful action called "Connect Bluetooth Midi Device with Name" in BTT, with the field "Enter the Device Name".
If I leave this field in blank, when I hit the shortcut, the Bluetooth Midi Window appears and I can select and connect or disconnect what I want. That's ok, no bug, no problem.
But if I write "*" in the field, or the name of my device, the behaviour is the same: the bluetooth midi window comes up but BTT doesn't connect nothing.
As instructions says, if I write "*" all availables midi devices should be connected.
Maybe I am doing something wrong or I don't understand it correctly....
Thanks for your help.
  • Type of Mac: Macbook Pro retina 15inch, mid 2015
  • macOS version: 10.14.6
  • BetterTouchTool version:3.206 (1382)
