For example, I would like to map a certain functionality to the three finger swipe on the left trackpad and different functionality for the same three finger swipe on the right trackpad.
To do this, will I be able to configure two Magic trackpads 2 separately on the same mac?
this is not currently supported by BTT but maybe it can be added in a simple way. It's on my TODO list.
I think it should now be possible with v4.727 alpha.
There is now a new advanced trigger condition variable trackpad_id:
That should allow to differentiate between different Magic Trackpads
This definitely is a workaround. But I still got a legacy license bought like 4 years back. Maybe I'll get a new license when this feature rolls out in the main workflow.
Ideally I would like to see both the trackpads in the top dropdown where we have all other devices (Touch Bar, Magic Mouse and then Trackpad 1, Trackpad 2).
Thanks for you response.
Yes, maybe it can be added there at some point, this is a bit more complex though.
For now the advanced trigger conditions will at least allow for this use case, they will be in the public rollout later this week.
Great! Thanks.
If i understand this post correctly two Magic trackpads should work on the same mac with or without BTT.
I have trouble connecting two Magic trackpads 2 to a MacBook Air (with also a Magic keyboard connected). See also my post:
