Initially, if I specify "Open in Another Application" and choose GraphicConverter it will work just fine. But the UI does not reflect the change that I have made. It will still show the original appearance. That is OK in that it works the way I want but it is not an optimal user interface.
Then I happened to notice that if I clicked again on the PopUp for After capture that Graphic Converter was now an option. So I selected that option and Saved it.
So that seemed good.
But then I reopened the Configure Screen Capture window and magically it had transformed to Preview which I had not requested and did not want. Functionally, this is what now happens, the selection is opened in Preview.
So I went back and used the Open in other application … option and chose once again Graphic Converter. The interface appearance returned to
I saved that and the desired functionality is restored.
In summary, I can successfully choose Graphic Converter but the UI does not reflect the choice that I have made. If I subsequently choose the -- app com.lemkesoft.graphicconverter11 -- option it will actually override that and substitute Preview.
- Type of Mac: MacStudio
- macOS version: Ventura 13.3
Version 4.068 (2283)
