I'm not entirely sure if this is a bug or just something that's confusing about the new UI, but the Config panel indicates that I am using the FN key in several places where I am not. I haven't been able to quite figure out the pattern yet, but the screenshot shows an example.
If you compare the Config panel with the with the Keyboard Shortcuts panel you'll notice that the shortcut does not use the function key.
- Type of Mac: Air
- macOS version: Mojave
- BetterTouchTool version: 2.856
