conditional activation group question
hello there
recently i tried to make conditional activation based on Android Studio focusing panel like editor section, terminal or error message section etc. Interest thing is on InteliJ IDEA its work correctly without any setting, using by Focused Element role value, but on Android Studio there is no change on this field. So I tried to find some solution but not much luck until now, something I could hear things is AXTextField made by Javascript. Is that possibilty to make some change on conditional activation
unfortunately not all apps support the macOS Accessibility API which is required for this - especially cross platform apps like Android Studio can be problematic.
You can search for "Accessibility API Android Studio", maybe there is a way to enable it via some setting (especially since IntelliJ seems to support it). I'll also try to find any information.
Thank you for response
by the way this guy looks like some how manage the situation but do you have any idea
Focused element sometimes not changed in Conditional Activation Group - #3 by GaborTorma
