I'm having an odd issue after Mac Restart or Wake from sleep, with BTT version 4.361, after upgrading from 4.333.
Mac mini M2 Pro, macOS 13.6.3, Stream Deck XL fully controlled by BTT
In BetterTouchTool Settings, General "Restart BTT after wake from sleep" is selected. The Priority Helper Tool is Active.
I'm using conditional activation groups to display sets of buttons on the Stream Deck based on the value of persistent variable: customVariable1. The variable is being set (seen in Scripting BTT Settings) but the buttons are not displayed. This happens after a Restart or Wake from Sleep.
Other conditional activation groups based on window name and App only sometimes work.
Groups based on Applications work OK.
Restarting BetterTouchTool will put things right — the buttons in the conditional activation group based on
customVariable1 now show. Conditional activation groups based on window name and App become reliable, once clicked. All seems to remain OK until the next restart or sleep.
I have found out what is causing this odd behaviour — BetterTouchTool is creating a temporary customVariable1, masking the value of the persistent variable!
This is very easy to demonstrate:
Create a normal Stream Deck Button in the active, Default preset.
Assign the BTT related action "Assign/Set Value for Variable":
Value: TEST
Type: Text
Select Persist
Open BetterTouchTool Settings — Scripting BTT
customVariable1 will be listed under Temporary Variables
Click the Reset All Variables button
Click Refresh Variables to confirm it's gone…
Restart BetterTouchTool
customVariable1 will again be listed with a null value under Temporary Variables
Press the Stream Deck button created in #1.
Look at Settings — Scripting BTT
customVariable1 will be listed under Persistent Variables with the value TEST
customVariable1 will also be listed under Temporary Variables with a null value
Restart BetterTouchTool again
There will be no customVariable1 listed under Temporary Variables
I'm guessing it may have something to do with that handy new box "Only set if no value yet" ???
I hadn't realised you'd done that along with all the other stuff you're doing… Just tried BTT Alpha 4.369 and the Stream Deck is once again behaving as intended… Apologies for not testing and getting back to you sooner.
