This is probably a solved question, but I cannot seem to find the answer anywhere.
How can I set a conditional activation group to a single chrome tab (eg. Google Docs, Twitter)?
Thanks in advance.
Thanks in advance.
Try to use the window/tab title to match. If that doesn't work you may have to install some extension that adds the URL of the website to the window title.
My preset has safari widgets, maybe you can take a look and apply it to chrome.
It usually uses the window name, but in some cases it reads the URL using applescript. Should be easy to adapt to chrome as it has pretty similar applescript syntax
Thanks for that. Actually, I managed to fix it by reinstallling chrome, there must have been an issue. After that BTT could recognise the window title.
