Hi there,
I was wondering if it would be possible to combine a mouse click with any other key instead of just having shift, fn alt, opt and cmd available. E.g. A+LeftMouseClick -> Triggering Shortcut
No, because there is no way to know that you will be clicking. Therefore this would effectively disable the A key.
Hi Andreas, sorry but I think don't really get this. What is the difference of holding down e.g. FN+MouseLeftClick and A+MouseLeftClick?
The difference is that FN doesn’t produce any visible key input (that's why they are called modifier keys)
A+click would always either lead to an a being typed, or a being blocked completely.
Thanks Andreas for clarification
Amazing plugin, though!
