It seems to be pasting all in one line, ill find out how to do a manual install
If you want to post code in this forum use three backticks ``` at the beginning and the end. E.g.
Ah, that's why it was all one line, thx
click the first link and it will download an installer
installing...
downloaded. what now?
I'd say try manually refreshing all the widgets while a song is playing
didn't work...
remembber I'm using Spotify
I remember. I have absolutely no idea how this possibly could fail but I'm not going to stop working on this preset. I'll likely have a much better version after a few days and I'll reply here if I have any breakthroughs. If you're still interested you'll see a new version a little down the line.
okay. thanks for all your help.
Good information thanks for sharing
Fieldengineer
Thanks for the widget.
One bug fix: You need to change the path /Users/YourUsername/Library/Application\ Support/BetterTouchTool/cover.jpg to ~/Library/Application\ Support/BetterTouchTool/cover.jpg inside the Spotify AppleScript. It is not the same for others.
Also it seems that when you copy paste the widget the UUIDs changes and brakes everything.
There might be a better solution to point on widget to another ?
Also I don't understand why the "next" widget has an apple script attached to refresh the other and not the "previous" one ?
Would it be possible for the widget to disappear if not song is playing ?
It's taking a lot of space if not used
Hi, Iām glad it works! Iāve been encountering tons of bugs. I thought I fixed that path, whoops.
As for the next/prev buttons, I just assumed people would only use the next button to change the song, but now that you mention it Iām definitely going to include a refresh on the previous button also.
About hiding the player when nothingās playing, its tough to determine when nothingās playing. I wouldnāt want to hide the widget every time you pause a song, and if you change the application thatās playing media it will hide the player. You can fine tune when youād like the player to show in the setting of the condition group it sits in. For example, youād be able to show the player only when the music/Spotify app is focused, or only when itās open.
Iāll be fixing the path bug and releasing a new version that addresses all these bugs in a little bit.
is there anything that helps me yet?
Hang in there, Iāve been tied up but Iāll have a new version this week. Glad youāre so determined! I hope you love it once I get it working.
I definitely will
