I use a lot the visual separators (VS). I use several color combinations for background/font depending of the function of the VS.
It would be possible to have a drop-down menu to save/set the color configuration with a name preset?
As example, I would like to save a preset called "MyTitle" that is white font over blue background and another preset called "MySubtitle" that is blue font over black background.
Then, every time I add a VS in BTT, I could select "MyTitle" or "MySubtitle" to set the combination of font/background colors very fast and very easy.
