When you create a TouchBar Button and set a Color that has a transparency factor, that transparency is never applied.
For example, create a TouchBar Button and give it "blue" apple color like in the screenshot, apply transparency.
That Blue will be the exact same as if you apply no transparency.
It seems to be the same problem with all colour types
I am on the latest stable release 3.108
Any ideas on how to solve this?
