When I use Clipboard Transformer Function (JavaScript) the BTT app crashes once I have used my shortcut 10 times (probably a memory problem.
However I use the javascript recommendations as explained, with a return
Here I use a shortcut with "fetch" to use the OPEN AI API.
My first "showHUD" starts, but the app stucked after that.
I see that I have the same problem if I use things like "setinterval" or whatever.
How can I easily debug my code, other than seeing BTT be stucked?
Thank you
Can you post the full code of the script here? Then I can try to see whether it's somehow leaking memory
By the way, 4.485 alpha has a native "Transform Clipboard Contents With ChatGPT" action if that is all you need!
Ok never see it before, just seeing the Transform & Replace Selection with ChatGPT
which never working for me.
But I guess I can have move flexibility using request
directly on OpenApi, like use my own key
The action also allows you to use your own key (it requires the latest alpha version)
I'll have a look at your script soon!
All features with ChatGPT inside BTT directly failed on my side.
Could you go to help => export diagnostic debug information and send the result to andreas@folivora.ai? The logs should contain any error returned from OpenAI.
