I have reported this before here but got no reaction. Since the exact bug changed a bit, I am re-reporting it now.
Note:
I have configured the BTT clipboard manager (CM) to automatically hide when I click outside it.
If I open the CM, then open its settings window; then click outside; then this closes the CM and the CM settings.
If I now reopen the CM, I cannot access its settings anymore. The button for opening the settings is permanently in a "selected" state (rendered darker).
Restarting BTT fixes this.
Here you can see the settings button in its stuck state.
- Type of Mac: MacBook Pro (14-inch, 2021) with M1
- macOS version: 12.7.6
- BetterTouchTool version: 5.137
