This may be self-evident, but I can't figure it out.
How do I define an action as click and hold?
(I need both left and right click).
Ah. Figured it out.
Under Custom Click, Trigger only mouse down, Left/ Right Click.
I knew this had to be trivial.
(Still getting used to the new UI).
I cant seem to find the "Custom Click" option, is it a trackpad setting in BTT or is this post wrongly marked as Trackpad topic.
What I am trying to do : MS Teams has a whiteboard feature, but to draw, you will need to press down on trackpad and draw with finger and that is nearly impossible. So if I can setup a key combination that trigger press and hold, I could use that and then draw with trackpad normally. Any thoughts?
Same - unable to find Custom Click
None of the options here are a solution to create a "click-hold" and "click-release"
same, there is no solution for click and hold. was trying to find a solution to triple tap the Magic Mouse to just tap the 3 fingers and hold it to create a drag option. seems you need to actually tap it?
