Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-). If you encounter a crash, please attach a crash log from the macOS Console.app's "Crash Reports" section.
Hi, you have Wonderfully designed the one tap clic finger on BTT for pc users who have trouble using the actual one tap click finger in use for Mac. I have tried it many times but it looks like it has a bug as, when writing an email, even if not touching the trackpad, it moves with sentences or words and then messes with the text. could you please check on your end wether the issue would come from me by not using it properly or with wrong settings or else please?
many thanks in advance.
- Type of Mac:
- macOS version:
