Circular floating menu is not circular
I have the latest alpha installed that would be version 6.334 and I have restarted the computer.
I create a new floating menu. I haven't even set up any details; I just added placeholder menu items and gave them icons, and no matter how I tweak the size or anything, it just is not circular.
When I switch to some other shape like column then it works normally.
I'm on Mac Sequoia 15.6.1
Any ideas?
Ah, I've just tied and indeed it is the same on my end.
The circular appearance only relates to the layout of the items. It is important to set a proper width and height for the menu. Best start with the circular menu template.
To make the container itself round you'll need to change the corner radius
