Note:
- Chrome icon is not properly showed in side panel (I don't know how to call this, the screenshot below says better), and is "mixed" with the icon of "recently used triggers"
- When I click the "mixed" icon, it shows the recently used triggers of Chrome only
- Restarting btt will solve the problem but the problem will occur again some time later.
- Type of Mac: MacBook Pro, chip: Apple M2 Pro
- macOS version: Sonoma 14.3.1 (23D60)
4.465
