Choose monitor when using "Move Window to Next Monitor" action
I am using the action "Move Window to Next Monitor" as a shortcut to rotate the active window on each monitor until it reaches the desired one. It works beautifully.
There's a minor problem: When the monitors have different resolutions (say, 4K, 2K then 1080 respectively, for example), when the window is moved from the higher resolution one to the lower one, the window's height will be limited to the height of the monitor. Then, when moving it back to the higher resolution one, the window is no longer maximised.
So, will an option of choosing which monitor to which this action will send the window be helpful? I am thinking of a list of monitors and using checkboxes to include/exclude specific ones.
Thank you.
