Check for regular updates shows Alpha releases
When clicking on "Check for regular updates" it opens a window showing me a new version is available, but shows the release notes of the Alpha version as can be seen in this screenshot:
It shows the same window, when I click on "Check for Alpha Version Updates".
As I don't want to be on the Alpha version, I am confused.
  • Type of Mac: MacBook Pro M3 Max
  • macOS version: 15.3.2 (24D81)
  • BetterTouchTool version: 5.267 (2025031105)
when manually checking for updates it will sometimes also show versions that are deemed stable enough, but are technically still in alpha testing. Stable releases will show automatically, no need to check for updates to receive them.
