Dirk
1
Describe the bug:
Changes in AppleScripts are saved, but the previous version is still executed. A restart does not help.
The only option is to delete the entry and create a new one.
- Type of Mac: MacBook Pro M2 Max
- macOS version: 15.0.1
- BetterTouchTool version: 4.811
where are you configuring the apple scripts? And are you using them inline or as an external file?
And it’s really apple script, not JS?
Dirk
3
Inline:
The error was reported once before in 2022, but did not occur for me until now. But now it is permanent.
thanks , I think i have an idea what can cause it! Will upload a fix later.
If you create a new one, does updating that one work or does it only work one time?
Dirk
5
It only works once. After that, you have to create another action to make a change.
thanks for the details! A quick workaround might be to set it to „preset file“ instead of inline
hope this is resolved in 4.812, will be available in ~10 min
