Changes/Actions to Middle Click does not work
Hey all, for some reason, any changes to the Middle Click action does not seem to work. I've tried changing the Left Click action, and that worked without a problem. I'm using Logitech G502 Hero and I've also downloaded the G Hub application to see if that would help but it did not change anything. I'm on Sequoia 15.5 and BTT 5.444.
Any help is appreciated! Thank you!
what do you mean by “ changes to the Middle Click action”?
Hey Andreas,
I mean assigning an action when "Middle Click" is pressed on the mouse. I originally created a thread for asking why the action you can see on the attached screenshot wasn't working but then I found out that no action works for "Middle Click" on my mouse.
Do no actions at all work? Does it show up in "Recently Used"?
It doesn't show up in "Recently Used" no. And so far no action worked.
I'm pressing "Middle Click" on my mouse to record the mouse button and it successfully assigns "Middle Mouse Button". So it detects the click, the middle click also works with everything else in the OS, like opening links in a new tab, closing tabs etc.
most likely there is some other mouse utility (e.g. the logitech drivers) that catch the middle click before it reaches BTT
