Change mouse speed when normal mouse present
Today the normal mouse speed is controlled by the speed set in "Magic Mouse" settings.
This is an issue as most regular mouses operate in a much higher DPI than the magic mouse, and it will move much faster and will be unusable.
There should be a different speed control for regular mouse, which will solve that.
I need this too
Can confirm the issue is still present. Changed the Mighty Mouse speed and it affected my Razer Basilisk speed as well. Pretty annoying.
