theres a script used to search a song playing in spotify on genius.com but it currently only works with safari.
this is the script
--@Felipeforerome Adapted from the iTunes Song.Link widget
----GET SPOTIFY LINK----
try
if application "Spotify" is running then
tell application "Spotify"
try
set theTrack to name of the current track
set theArtist to artist of the current track
end try
end tell
else
return ""
end if
tell application "Safari"
activate
tell window 1
set current tab to (make new tab with properties {URL:"https://genius.com/search?q=" & theTrack & " - " & theArtist})
end tell
end tell
on error
return "Couldn't open Genius"
end try
If I change "Safari" to "Brave Browser" which is the full name of the application the script doesn't run
