I've looked but can't figure it out - when I snap a window to the top, which then is a full size window, if that window has a predetermined resolution that won't match the monitor, the window always snaps to the top left corner.
Is there a way to snap it to the center?
If my screenshot worked, then you can see I'm using Microsoft Remote Desktop and it doesn't scale to match my monitor resolution. I'd like it to be centered and not pushed left.
Thanks,
Don
