I'm trying to get the Siri Remote gen3 working with my old-assed iMac (recently upgraded to Catalina, highest it will go). Will this remote be compatible? I've got another couple weeks to return it for a refund if it isn't.
Someone on apple.stackexchange.com suggested that I might need an older version of BTT, but I'm not sure what version I'd need, let alone where to find those.
The specs page says BT 4.0 (have to scroll down a bit, but it's there). Despite that, the remote only shows up as a generic device (keyboard icon) in the Bluetooth device list.
unfortunately you wouldn’t find drivers that work on older macOS versions because Apple doesn’t release then. You can’t copy the ventura version to a catalina macOS unfortunately
This is frustrating. I can see the packets received when I sniff it with Bluetooth Explorer on this mac. I can read the battery level, see the audio when I hold the microphone button. So close, yet so far.
yes, it was completely trouble free. You can even install standard macOS updates afterwards. I have had it running on multiple older Macbooks for quite a while.
Only limitation is, SIP can not fully be enabled on patched systems as far as I remember ( but it will probably still be way more secure than running macOS 10.15)
//edit: I think on the 2013 iMac even SIP is supported, in that case there really isn’t any noticeable difference to an officially supported version
Thank you. Ventura's installed, it seems to be working fine. Worth the upgrade even by itself. I have some success getting the remote to work now, though I suppose it'll take awhile to configure it the way I'd like.
