Would it be possible to add case sensitivity to triggers (typed words) in Key Sequences? E.g. DDD is a different trigger than ddd.
Thanks for considering!
That's already the case because it will take the shift key into account. The keq sequences don't work based on letters but on key presses.
That's awesome! Ok. I must be doing something wrong. I'll give it another shot. Thanks for an AMAZING app.
Yes. Just tested and it works as described!
Not sure what I was doing before that was breaking things, but it's working great now.
Many thanks!
