Capture stdout of shell script
I am building a "Transform & Replace Selection with JavaScript" action. I have been trying to capture the output of a shell script that does IO. The script in question is a pretty widespread Python CLI interface to remote and local LLMs (GitHub - simonw/llm: Access large language models from the command-line).
async (content) => {
   let cmd = `/path/to/llm  "${content}"`;
   let resp = await runShellScript({script: cmd});
   return(resp);
But the output doesn't get captured. Probably because of IO delay. Indeed, the following does work:
   let cmd = `echo "${content}"`;
   return(resp);
When I run llm --help as the command, the help message get captured (no IO involved) too. But when I run a query, as shown above, no output get captured. (Needless to say, it works fine in the terminal).
Any idea? (Is there a way to specify a timeout, for instance?)
I found a solution: piping the query to the llm command rather than passing it as an argument (both work in the terminal).
   let cmd = `echo "${content}" | /path/to/llm`;
returnToBTT(resp);
Thanks for BTT by the way (I bought it two times. It is, by far, the best helper tool on OS X that I have ever used. Quicksilver comes second).
