Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-). If you encounter a crash, please attach a crash log from the macOS Console.app from the "User Diagnostic Reports" section. ![]()
I have caps lock set to Act as Hyper Key, with a named trigger to toggle caps lock. This was working fine until a couple of days ago (I was on version 4.3-something). Now capslock is toggled any time I use my hyper key, even if I remove the named trigger. Any Named Trigger I try to use with Hyper Key "when released without having been used" now no longer works. I'm currently on 4.442 and the issue is still there.
MacBook keyboard and external USB keyboard
- Type of Mac: MacBook Pro 2021
- macOS version: Ventura 13.4.1
- BetterTouchTool version: (please post the exact version - not just "the latest one") 4.442
