When typing in either word or notes or anything else, pressing the caps lock button sends a "left click". so if i type a paragraph and the mouse is not at the end of the paragraph (why would it be?) pressing the caps lock button will move the cursor to wherever the mouse is. very disorienting.
After checking the chart it shows a "left click" action that correlates with the caps lock issue. Its definitely BTT as the caps lock button does not send a "left click" when BTT is closed.
The affected input device is the keyboard
- Type of Mac: MacBook Pro (13-inch, 2017, Four Thunderbolt 3 Ports)
- macOS version: 10.14.5 (18F132)
- BetterTouchTool version: 3.157
The only workaround ive managed is to either quit BTT when i need to use the capslock button or make sure the cursor is where it should be before pressing caps lock. Sorry if this is a feature and not a bug but i have been unable to locate the setting to enable/disable this functionality.
