Caps Lock → Command(R) Remapping Not Recognized in Key Sequence Recording (BTT 4.997)
Note:
When the Caps Lock key is remapped to Command(R) via macOS (System Settings → Keyboard → Modifier Keys), BetterTouchTool (BTT) 4.997 no longer distinguishes whether I’ve pressed Caps Lock or Command(R) in its Key Sequence recording feature. This used to be clearly recognized in previous versions of BTT, but now the keypress is not differentiated.
This issue is particularly problematic for many Japanese users who prefer to use a US keyboard with macOS, because we often rely on using Command(L) or Command(R) to toggle between Japanese and English input. We also repurpose the Caps Lock key as Command(R) for shortcuts like Command + C, etc. Since BTT no longer detects the difference between a remapped Caps Lock and a true Command(R) key, it breaks these workflows.
It would be greatly appreciated if you could fix this so that Caps Lock remapped to Command(R) is recognized as Command(R) in the Key Sequence recording, just like in earlier versions of BTT.
  • Magic Keyboard (US Layout)
(No screenshots available for this issue, as it involves keypress recognition.)
  • Type of Mac: Mac mini 2024
  • macOS version: 15.2
  • BetterTouchTool version: 4.997
  • I am using the built-in macOS modifier keys remapping (System Settings → Keyboard → Modifier Keys) to change Caps Lock to Command(R).
  • In previous versions of BTT, this remapping was detected properly in Key Sequence recording.
  • The issue seems to have started at least from version 4.997.
Thank you very much for looking into this issue. If you need any additional details or logs, please let me know!
I tested the latest alpha version (4.9992), but unfortunately the behavior remains unchanged.
I think I found the issue, can you try with 4.9993? (uploading now will be available in 5-10min)
Best do the remapping in BTT:
I saw this thread and updated it to 4.9996, but the operation did not change.
When I assigned Caps Lock to Command(L) using BTT's remap function according to your suggestion, it became a practical operation.
Now you can resume your comfortable work.
Thank you.
However, this is only a workaround, and the movement is different from the original action.
There may be other Asian language users who are in trouble using IME.
I hope the bug will be fixed.
