Following these instructions: Defining a Hyper Key · BetterTouchTool Documentation , I set Caps Lock as my Hyper Key. I also set a trigger so that Caps Lock still works when the Hyper Key is not used. All of this works perfectly. Unfortunately, I notice a slight delay when activating Caps Lock. In my opinion, this delay is added directly by MacOS, ref.:
- Caps Lock Delay - how to fix it - Apple Community
Before I set up HyperKey, I used this hack:
hidutil property --set '{"CapsLockDelayOverride":0}'
However, it seems that this does not work in conjunction with BTT. I tried installing https://hyperkey.app/, which works more or less the same as Hyper Key in BTT, and I don't have this problem with this application. When Caps Lock is pressed briefly, it is activated immediately. But of course, I would like to use BTT exclusively.
Does anyone know if there is anything that can be done about this? Some kind of hidden config or something? Thanks.
