Caps Lock as Hyper Key - Advanced Conditions
as many others I have configured the Caps Lock key to act as Hyper Key.
This generally works well, but occasionally I have issues in conjunction with VMware Fusion (specifically running Virtual Machines) where the key then turns on the actual Caps Lock function on my keyboard.
For that reason I would like to have the Caps Lock key act "normal" within VMware Fusion.
I have set
active_app_name != "VMware Fusion"
within the advanced conditions section for the BTT Caps Lock key configuration, but that does not seem to work.
Shortcuts using the Hyper Key still work when VMware Fusion is the active application.
Any ideas?
(BTT is currently at version 4.9997)
Sebastian
