On the Keyboard Shortcuts page of preferences, I set left half to control-left arrow (^←), but then when I try hitting those keys it does nothing. Same issue for right half: control-right arrow. I am able to use control-up arrow and control-down arrow. I can also use command or option plus left/right arrow keys and it works correctly. Not sure why these 2 aren't working, maybe some other app already is using those shortcuts?
I am transferring from my old 2015 MacBook Pro that was able to use the control-arrow setup and have my muscle memory set to it. It was also running Mac OS 12.3. Not sure what is different with this setup.
Thanks for any help you can give on this.
- Type of Mac: MacBook Air M1
- macOS version: 12.3
- BetterTouchTool version: 1.9.5
