MacOSX: 10.13.5
BTT: 2.530
I created a new user on my mac. So, I clicked on: Managed presets, highlighted the default, export highlighted. I tried this twice by selecting Triggers & Setting, then Only Trigger and saved to my desktop. Default.bttpreset saved to the desktop. I transferred the file to my TimeCapsule. I then logged in as the new user, transferred the Default.bttpreset to the desktop. Opened BTT preferences, manage presets, Import, then selected Default.bttpreset.
It didn't import presets, as nothing had added, but it created a new Default. Now two defaults are listed. I check marked both as active. Nothing. The applications didn't even load on the left. Am I doing something wrong?
I'm having the exact same issue.
