There are many webpages that does not automatically recognize the cursor navigating a text, therefore, the only way to instantly select a text is by force click and drag for copy/paste/highlight purposes. there is no trigger on BTT allowing me to activate force click and drag, I have tried different workarounds in action sequence, but they are not as practical and efficient as force click and drag. is there something I'm missing ?
Can you give an example of such webpage?
