Can we add direct entry options next to numeric sliders?
Howdy! I was wondering if there would be any interest in adding direct value inputs (e.g. <input type="number">) next to numeric input sliders. Perhaps they could be accessed by clicking on the numeric preview to the right of the slider, transforming it into a direct input. Or alternatively, I think photo editing software scales down the slide rate if you hold shift (or some modifier) allowing you to make micro adjustments on a slider.
I'm configuring key repeating behavior and prefer a fast trigger and a fast repeat rate. On MacOS, I have both "key repeat rate" and "delay until repeat" set to their fastest values in the native OS keyboard settings menu. To match the same repeating behavior in BTT, I'd need to set the delay and repeat values to 0.1 and 0.05. The issue is the numeric input sliders for these settings go from 0.00 - 2.00, which means that I need pixel perfect precision. Not impossible, but the difference between 0.04 and 0.05 is too small for me to drag my finger on the trackpad, so I end up swinging the slider back and fourth hoping to land on the correct value.
While I'm sure the argument could be made that it's fine to get it "close enough," seeing all the sliders on close-but-different values would bug me.
you can already click the number and enter via keyboard :slight_smile:
Well shoot man! I'm sure I tried, but there it is now. I was suspicious that no-one else had raised this topic, and now I know for sure there's just egg on my face. Thank you!
I've also recently found out this. The UI really does not make it obvious :slight_smile:
