indeed, thanks!
did you just change the way BTT interprets quotes and dashes? just before installing the update today, I could input these as expected... terminal itself does not replace them, and it would be "smart" to not replace them in this kind of input window?
I've been having trouble with Cmd/C Cmd/V copy-and-paste for a few BTT versions now.
I'm running Mojave on multiple machines, BTT version 2.750. Appears that nothing is being copied to the clipboard. In fact, just tried to copy-paste the URL from this browser window...nothing. Exiting BTT restores the expected behavior.
Possibly try 2.760 there have been many fixes.
However in your case it sounds like you have configured cmd+c and cmd+v shortcuts in BTT that override the default system shortcuts? (The original topic was about cmd+c and cmd+v not working in BTT itself)
Thanks for the quick response. I haven't configured any keyboard shortcuts, and just three global trackpad gestures. The symptom is that a Cmd-C doesn't place anything onto the clipboard; this turns up in most of the apps that I use. Most of the time clicking Cmd-C several times will 'catch'. I think this began on the first Mojave update, and I see it on three different machines.
Unfortunately I haven't hear of such an issue before thus I assume it's some configuration issue (if it was a general thing I had already received tons of emails :-)). If you want you can send me the debug information (About Tab in BTT => Export Debug Information, this will create a folder called BetterTouchToolDebug on your Desktop which you can send to andreas@folivora.ai)
I ended up doing a complete uninstall (using App Cleaner) and a reinstall, which seems to have solved the issue. I've used BTT for several years...might be that I had a corrupt plist somewhere after multiple upgrades and machine swaps.
BTW I teach CS at university, and every semester I'm asked what tool I'm using that does the 'cool snaps' and gestures durin lecture.
I know this is an old one but I'm having the same problem on a Macbook Pro 16".
I have restarted the entire computer as well as BTT several times. No luck.
