Bypass system privacy setting keeps popping up
After updating to Sequoia 15.0 I had some popups to set the privacy & security settings. One thing I noticed (I guess this is new) that you can now "Allow For One Month". I think I used that function the first time, but now every day this popup appears one or two times. I tried removing the permission manually and adding it again, but somehow the popup still gets triggered.
I searched the forum and saw some other issues with security settings. One tip was to enable Full Disk Access. That one was allready active, so I'm not sure if that does the trick
Anyone else had this problem of returning popups? And maybe an idea how to fix it?
Greenshot 2024-09-24 11.25.01
Sounds like a macOS bug.
You should be able to disable the popup with this terminal command (at least for the next 1000 years):
defaults write ~/Library/Group\ Containers/group.com.apple.replayd/ScreenCaptureApprovals.plist "/Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool" -date "3024-09-23 12:00:00 +0000"
You might need to adapt the path if BetterTouchTool is located somewhere else
