Button + Mouse Wheel for Smooth Zoom In/Out
What I want to achieve: Hold right mouse button + Mouse Wheel up/down for smooth zoom in/out.
Unfortunately, right click is not shown in sidebar. Is it not possible to use this as trigger?
I used middle click instead, and could not find suitable actions. “Zoom In” and “Zoom Out” actions were rather clumpsy. “Start smooth zoom” just starts the zoom, but I want to control it with the mouse wheel.
What action would you recommend for continous zooming with the mouse wheel?
scrolling + right-click is complex and not really possible in a good way currently. You can configure it using scroll modifiers but it would always lead to a right-click once you release the button press.
Maybe click+drag up/down would work for you?
Thanks for the quick response.
Would middle mouse button + mouse wheel work? I really would like to use the mouse wheel.
It can work if you set up a scroll modifier and assign an advanced condition
currently_pressed_mouse_buttons == "2,"
However it will still produce a middle click once you release the mouse button
Thanks, I think I can work with that. However, how do I configure the wheel up/down trigger/action for smooth zooming?
you don't, you need to use a scroll modifier like shown in the screenshot above
Works great, thanks!
