Bug - "Transform and Replace Selection with ChatGPT"
Since yesterday, the "Transform and Replace Selection with ChatGPT" option no longer works. It causes a crash and systematically closes BetterTouch upon use.
It doesn't work with my OpenAI API key either
which BTT version / macOS version? (if possible always use the issue template)
  • Type of Mac: MacBook Pro 2019
  • macOS version: 14.4 (23E214)
  • BetterTouchTool version: 4.451 (44510)
Thanks a lot, should be fixed in 4.452! (uploading now)
Perfect, thank you very much for fixing the bug and your reactivity, it's working again.
Have a great day,
