BUG: short/long press shortcut
@Andreas_Hegenberg If this isn't just happening to me, then it's probably a bug.
What you see is: “j” is pressed and held while “a” is typed in rapid succession. Then I stop typing "a" and release “j.”
As you can see, “j” is typed, but that shouldn’t happen. Because “j” is set up so that it’s typed within 0.15 seconds of releasing the key. This time limit was clearly exceeded.
Could you please have a look at this when you have time? Thank you very much?
yep the reset happened on any keypress because I was lazy when I implemented this :joy:
Fixed in 6.710 (will upload in a few minutes)
Thanks :folded_hands: :joy:
