I disabled "Secondary Click" in mac Trackpad options, because I want to assign 2 finger tap and 2 finger click to two different functions rather than a secondary click
I also disabled "Smart Zoom" in Trackpad options, so the 2-finger tap in magictrackpad should trigger no delay and very quickly( If enabled Smart Zoom, there will be a delay to trigger two-finger tap,that is, to figure out whether you are trigger smartzoom or secondayclick , in macOS )
I set 2 finger click and 2 finger tap to different function , I set 2-finger click to 'command+ w', and 2-finger tap to 'right click' ,to expect perform a normal seconday click
result:
the 2 finger tap can't produce 'right click'' very quickly, there is a delay and lag
MacBook Trackpad
- Type of Mac: macbookpro 16inch 2019
- macOS version: Catalina 10.15.7
3.553
