unless you have created that variable manually (or some script), this does not exist. See this for the correct names
Thanks, translated_active_space works fine. Active corners must always be restarted after editing BTT in order for them to work (minor bug).
I can now set the move from the space to the nearest space, but I can't set the move from the full screen application to the nearest space. Can this be done in BTT please?
