BTT would not start after configuring bluetooth LE trigger
I just started to configure a new trigger on Bluethooth LE (Experimental) ... before i finished configuring it, BTT crashed and would. not restart. I rebooted my machine ant it still would not start.
Eventually i managed to click on the configuraiton menu before it crashed on starting up and obtained the stacktrace below.
To fix the issue i had to go to my privacy settings and grant access to bluetooth to BTT ... i should have been promped to do this when i started using that trigger... or at least BTT should not have crashed.
  • Type of Mac: Macbook Pro 2018
  • macOS version: Ventura 13.1
  • BetterTouchTool version: 3.402 (1633)
Staktrace snipeet
"sip" : "enabled",
"exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
"termination" : {"flags":518,"code":0,"namespace":"TCC","details":["This app has crashed because it attempted to access privacy-sensitive data without a usage description. The app's Info.plist must contain an NSBluetoothAlwaysUsageDescription key with a string value explaining to the user how the app uses this data."]},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 7,
"threads" : [{"id":18463,"queue":"com.apple.main-thread","frames":
Unfortunately recent macOS versions require a change which was not available in the BTT version you are running (v3.402 is from 2020). Upgrading BTT should solve this.
