Hi there,
I tried to create an workflow to download documents with the Moodle app for Mac. Its soo annoying to repeat the steps below for every course. (Circles show the space where to click)
Every time I start it, it stops after two steps, but I don't know why...?
Does anyone know what im doing wrong?
Thanks a lot.
I think you might need to add some delays because otherwise the browser will basically receive all the click & move events right after each other and may not be able to respond fast enough.
However in general running a little bit of java script would probably be a better solution to this, but I currently don't have access to a moodle instance to test that.
